It is currently Fri Aug 15, 2025 12:23 am
Post new topic Reply to topic  [ 109 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed Feb 25, 2015 11:38 am
The key to the process may be the amount of torrefication used. Commercially torrefied lumber may too crisp for good tone wood. The guys at Martin seem to understand this. I wouldn't want to build with "driftwood" dry wood, but I do like spruce when it is about 50 or 60 years old.
Last edited by Barry Daniels on Wed Feb 25, 2015 11:46 am, edited 1 time in total.
These users thanked the author Barry Daniels for the post: DanSavage (Mon Mar 02, 2015 1:17 pm)
PostPosted: Wed Feb 25, 2015 11:43 am
I have 50 year old spruce, and it does not feel like the torrefied stuff at all.
PostPosted: Wed Feb 25, 2015 11:45 am
But it doesn't feel like new wood either, does it? So could it be described as just less torrefied?
These users thanked the author Barry Daniels for the post: Dmaxwell (Thu Feb 26, 2015 12:19 am)
PostPosted: Wed Feb 25, 2015 12:08 pm
No because presumably it hasn't been through any deliberate thermal treatment. So it's not torrefied at all, just very well seasoned.
PostPosted: Wed Feb 25, 2015 12:57 pm
I have some recent experience with roasted maple. It doesn't bend very easy but seems to be brittle - I gave up making tight bends (there's a thread on this). On the iron I just didn't feel it release like the natural maple. If you put water on it, it gets wet so it may be more stable with humidity changes but not immune by any means. Finally - no problem at all gluing with Titebond. I doubt if there will be any issues with HHG, fish, or CA. Of course I'm talking maple and not spruce. I would expect spruce to be better behaved.
PostPosted: Wed Feb 25, 2015 1:29 pm
There have been examples of torrified wood used by obscure manufacturers with import instruments for years now. One example that we encountered was a maple fretboard that had been torrified and was used on an electric resonator.
The material, at least in that case, was completely unserviceable in so much as carefully "lifting" frets resulted in not just chipping but large chunks of the fret board crumbing and falling off.... In the end we scraped off the entire fret board and we have our pal Andy Birko making us a replacement.
Of course I can't speak to the level of torrification that this manufacturer went to and that's an important distinction as well. But I do know from personal experience that at some levels the material becomes a crispy critter and in this case made the instrument basically disposable when the economics of repairing it aren't there.
Don't get me wrong I'm not an anti-torrification nazi by any means but I am skeptical and will wait for one of the fat ladies that you guys craft to sing before passing judgement. I also wonder how that all important bridge glue joint will do or if unnatural acts such as hardware.... will be required to keep things in place.
Part of me does want to say something such as sheesh we have Tonerites...., torrification....., fossilized Mastiff Turd.... etc. Doesn't anyone want to wait and be part of the opening up process of a fine musical instrument anymore.... What's the hurry....
Some tests that I would like to see are:
1) Gluing tests simulating all manner of the important joints on an instrument with specific interest in bridge glue joints under constant tension with RH swings..... You know, real life...
2) Dent and ding resistance tests, could be fun to do...
3) Weight and stiffness with deflection testing prior to and after torrification.
4) Finish adhesion testing.
5) And the big kahuna blind listening tests of two identical instruments with the only difference being the top one torrified, one not. Would like to see this test done when the instruments are brand spanking new, after one year, and after five years. If you could plot results going out several decades one has to wonder if at some point there are diminishing returns.
6) Lately we feel like proctologists in so much as this is our busy season and we are up to our elbows in cracks.... No jokes please, well maybe a few... :roll: Anyway about half of the repairs that we are doing at present are crack repairs be it spruce, mahogany, rosewood, etc.
Part of the drill with a dried out instrument is to rehumidify and let the natural swelling of the wood aid in closing the cracks. As such one has to wonder how well torrified wood will retain the trait of swelling when exposed to high RH. Sure you can make the case that torrified stuff is less likely to crack because of RH swings in the first place but not all cracks are from RH swings. You have clients that sit on guitars, jealous lovers that throw them down the stairs, the Martin that was shot with a shot gun that we repaired, you name it.
It could be that all this stability, if this is actually the case, could require different repair activities to deal with it.
Lot's of questions and so little time so you brave guys who are on the bleeding edge of torrified tops thanks much for reporting to us as you are. [:Y:]
PostPosted: Wed Feb 25, 2015 1:36 pm
First name: Greg
Last Name: B
City: Los Angeles
I am very skeptical about the long term durability of heat treated wood. Is there any data around comparing the toughness of torrefied wood to kiln or air dried wood? I expect fractures and other structural problems will start showing up soon.
The fact that this even exists is kind of funny because when I first got into this hobby, even kiln dried wood was seen as nearly a mortal sin.
PostPosted: Wed Feb 25, 2015 2:02 pm
I guess we'll be able to make guitars as good as Yamaha? They have been using torification for years and at least five years on guitars maybe more
http://www.yamaha.com/about_yamaha/research/are/
Ken Cierp
PostPosted: Wed Feb 25, 2015 3:03 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Guitars are predominantly made from wood. Wood expands and contracts. A guitar is always in motion, RH wise. Torrefied wood doesn't expand and contract? What, if anything happens to the guitar? I've got zippo guitar building experience, but know a fair bit about building furniture, cabinets, and wood movement. I know that guitar construction is at odds with some rules of woodworking, ie. cross grain gluing, but that allowances are made for this during construction, but what happens when you take top movement out of the equation? Are there any immediate considerations? Long term considerations?
What happens when tops that are off quarter or have run out are torrefied? That one I think I can figure out myself.
I'm not being a naysayer about torrefied tops, one way or the other.
I'm interested in what the experienced and knowledgeable have to say about this, because my knowledge is VERY limited. I asked a lot of questions as a kid, so I guess I haven't grown up yet!
Alex
PostPosted: Wed Feb 25, 2015 4:08 pm
First name: Big
Last Name: Jim
I will gladly jump on the band wagon in 5-10 yrs . Until then I will take my wood fresh and my pop-tarts baked . :D
PostPosted: Wed Feb 25, 2015 4:36 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
Who the hell bakes pop tarts? You need help, my friend.
PostPosted: Wed Feb 25, 2015 6:39 pm
Michael N. wrote:
"No because presumably it hasn't been through any deliberate thermal treatment. So it's not torrefied at all, just very well seasoned."
One of the interesting features of torrified wood is the reduction of hemicellulose, which also occurs in well seasoned wood. There might be some benefit to lightly torrifying soundboards to get that reduction of hemicellulose, if that in fact, improves the sound of the finished instrument.
PostPosted: Wed Feb 25, 2015 9:34 pm
this doesn't make the wood more brittle. I have made 2 guitars with this and they sold . They do have a different sound. The tops are very stable. The glue takes a little longer to dry as the tops don't absorb any water so you have to wait for them a little longer. I allow 24 hr clamp time.
They look old guitars without having to add toner. All I can say is it is just another thing a builder can offer to his clients. Last year Martin had the first of the torrified tops out for edapolusa and the 2 they had sold on the spot, they do have a more vintage sound than anything I have heard before.
The only way you can be sure is to make a guitar with one and decide for your self.
These users thanked the author bluescreek for the post (total 2): RaymundH (Thu Feb 26, 2015 8:59 am) • Alex Kleon (Wed Feb 25, 2015 9:36 pm)
PostPosted: Thu Feb 26, 2015 12:03 am
Shane Neifer wrote:
Josh H wrote:
kencierp wrote:
So the suppliers that claim air dried material is better than kiln dried material -- stronger/ more stable etc. Have that wrong? Torrification is a kiln on steroids. I have heard so many great sounding "brand new" guitars made with air and kiln dried wood --- I personally dismiss this as another fad sales gimmick. But on the other hand -- Yamaha has been using the process for years!!!!
But what Torrefication does to the wood is totally different from kiln dried wood. The guy who runs one of the companies that does this explained that after wood is put through the process it will no longer absorb or release moisture. It becomes stable. Stable wood for acoustic instrument building is really appealing! I'm sure some people will argue with that claim, but I'm just telling you what I've been told and what they have observed from testing the moisture content of the wood after it has been treated. I'm hoping to try building a guitar from entirely torrefied wood to test this claim. See how it survives a winter with no humidification...
Josh, I think the real test would be to send the guitar to a humid location, not a dry one. Another simple test is to just put the tops in the bathroom when you have a nice hot shower and see if they cup at all. If they do then they are picking up moisture. If they don't well then I guess his claims are correct. As has been said there are a few pretty amazing guitars around that have been built without doing anything to the wood other than letting it sit around for a while. I have a bias that part of the sound of good guitars comes from the process of the wood stabilizing while under tension of the guitar as a coupled unit and fear that heat treating of any kind may shorten the effective acoustic life of the guitar. I have nothing to confirm this so won't argue the point but that is my bias.
For this experiment to really work you would also need to use torrefied braces....
Old growth, shmold growth!
PostPosted: Thu Feb 26, 2015 12:38 am
I used torrefied braces on mine. We'll see what happens...
PostPosted: Thu Feb 26, 2015 4:00 am
It does make it more brittle, without question. It's a side effect of the torrefication process. Even Martins more gentle method results in a wood with increased brittleness, they admit it here:
http://onemanz.com/guitar/martin-vts/
Whether that greater brittleness is anything of a problem? I have absolutely no idea.
So it seems they wish to replicate the tone of wood that is a couple of hundred (or more) years old.
That may seem a little odd. Virtually all the blind tests done between the best modern Violins and the 300 year old Strads and Guarneris put the Modern instruments (non torrefied) ahead. There have been some notable rigorous tests done on this, not to mention many, many more that have been less scientifically rigorous. . . . but still blindfold. The modern instruments fair extremely well when the blindfolds are put on. They just don't do very well when the blindfolds aren't put on. Which should tell you a lot about how open we all are to suggestion.
Whether the torrefication process results in a wood that is exactly like that of 300 year old wood is another matter. It just may be that it changes things in a slightly different manner (who knows, perhaps even for the better), yet looks very similar under the microscope.
PostPosted: Thu Feb 26, 2015 7:42 am
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
Another perspective.
http://bourgeoisguitars.net/wp-content/ ... rs-MMR.pdf
PostPosted: Thu Feb 26, 2015 7:57 am
Would be nice if some of the suppliers of torrified wood would make samples available for folks such as us who would be interested in doing some testing.
It's understandable that those with skin in the torrification game would be defending the process and others would be being who they naturally are with new ideas. Seems the only way to break through to the other side (love that song....) is testing.
PostPosted: Thu Feb 26, 2015 9:19 am
I'm of the same opionion of John. If you want to know how it all unfolds, build one for yourself.
I purchased a torrified top for the same reason I first bought a Lutz and Carpathian top, I just wanted to see how they sounded.
Also, as many have mentioned here, companies such as Martin, Taylor, Bourgeois, Huss Dalton, and others are offering their warrantee's on these instruments. I would have to think that there were some back room discussions about any possiblities of top failures and claims?
Guitar Building = Continuous Improvement Process
PostPosted: Thu Feb 26, 2015 9:23 am
First name: Zeke
Last Name: McKee
Wood is so different from piece to piece. The best way imo to test the brittle factor would be to take a set of bookmatched wood. Torrify one side and not the other. Then test away.
These users thanked the author ZekeM for the post: Pmaj7 (Thu Feb 26, 2015 10:49 pm)
PostPosted: Thu Feb 26, 2015 9:28 am
First name: Jeff
Last Name: Dillard
Zeke M I do a torrefied poptart every once in a while.
These users thanked the author Jfurry for the post: ZekeM (Thu Feb 26, 2015 12:06 pm)
PostPosted: Thu Feb 26, 2015 10:00 am
Hesh .. you had it partially right .. the show is actually going to be called "Breaking Heshtone", where a cancer stricken luthier goes around finding and trashing all the Heshtones he can find, and then charges outrageous fees to fix them....
PostPosted: Thu Feb 26, 2015 11:58 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Quote:
Honestly I don't care for 18:1 tuners.
+1. IMHO, they are wasted motion, and lack feel. I prefer 12:1.
I have only played a few torrefied guitars, and I cannot see any great advantage...other than the stability. My solution for that is to use aged spruce.
PostPosted: Thu Feb 26, 2015 12:40 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
You should give the 21:1 a try, bliss
MK5acoustics.com
PostPosted: Thu Feb 26, 2015 9:42 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
In Soviet Russia, guitars torrifies YOU!!
Typhoon Guitars
